Rotate pivot to object normal?
chroma123
chroma123
Hi!
I have a case where I want objects imported from ArchiCAD to have pivots aligned to a certain way.
Every object should have the pivot facing this direction on itself: (these are detached objects from building walls)
I got a script to work, at least to an extent, which was modified from somewhere I now don't remember (sorry):
fn alignPivotToFace node face:1 type:#z_up = if iskindof node Editable_Poly do
c = polyop.getfacecenter node face
n = polyop.getfacenormal node face
ftm = translate (matrixfromnormal n) c
case type of
#x_up: prerotateY ftm -90
#y_in: prerotateX ftm -90
itm = ftm*(inverse node.transform)
node.transform = ftm
node.objectOffsetPos *= inverse itm
node.objectOffsetRot *= inverse itm.rotation
node.transform
p = $
alignPivotToFace p type:#x_up
This script "consistently" makes my pivot like this:
Which is a good starting point, I only need to get it aligned to leftmost down boundary box, and turned -90 degrees on the z axis. I didn't get this to work in the script, but I'm sure it works with an add of a few lines (Help appreciated here too). So far so good, as it doesn't seem like an unsolveable problem.
But when I'm executing the script, it seems like some polys from ArchiCAD aren't following the same terms.
Like this ****:
How can I get this to work...? Any way to force / embed a z up position in the "bad" polys, before executing the script?
I'm lost now, and banging my head against the wall. Big thanks!
har1sf0x
  I am not sure i have understood your concept but the following modifications might work:
	If your pivot is in the right position when you import your model do not change anything.
	If you want to use for instance the position of the 1st vertex change "c = node.pos" with
	"c = polyop.getVert node 1"
c = node.pos
case type of
#x_up: (prerotateY ftm -90;prerotateX ftm 90)
node.transform
p = $
Enjoy,
har1sf0x
chroma123
Hi, thanks for response!
It do align better, not it's not good enough.
Below, I've selected four detached elements, and you can see how inconsistently it works.
I can run the script once for each object, so I don't need any batch or while loop written in.
However, I really wanted this pivot alignment process to get automated through a script, but I'm no longer sure if it's possible at all.
This is how every object should have it's pivot aligned. Left (I know that's a tricky one, since rotation of the objects can vary)
and with the pivot just like this.
And seen in the bigger picture:
denisT.MaxDoctor
@chroma123 wrote:
Hi!
I got a script to work, at least to an extent, which was modified from somewhere I now don't remember (sorry)...
this is my function shown once on CGTalk
in your case it can be modified as:
mapped fn alignPivotToFaceZUp node face:1 = if iskindof node Editable_Poly do
	side = cross z_axis n
	up = cross n side
	ftm = matrix3 n side up c
	bb = nodeGetBoundingBox node ftm
	node.pivot = bb[1] * ftm
	node.transform
/* using
alignPivotToFaceZUp <selection or list of your wall objects>
 (of course if we expect our "walls" vertical
chroma123
Wow, thanks for clearing that up! Respect!
And for what you just wrote: What an amazing script. How did you learn to be such a guru?
It almost does what I want it to do, from what I've tested now.
Only thing is that it should be turned 90 degrees counterclockwise, so that the red arrow will be where the green is now (along the edge of the object).
Do you also happen to have a good solution to that?
denisT.MaxDoctor
	up = cross n side
	p = (nodeGetBoundingBox node ftm)[1] * ftm
	prerotateZ ftm -90
	node.pivot = p
	node.transform
chroma123
Thanks! I had to change -90 to 90, and then it aligned as it was supposed to. Big thanks again!
