Render to texture used maxscript issuse
Hey guys.
I got a trouble in save the baked diffuseMap used maxscript ,
Max had a bug maybe, that is in the vfb(virtual frame buffer) the texture looks wrong and saved texture is currect.
Now the issue is when I used maxscript to render the diffuse to save a texture ,the  resault is the texture in the vfb , the wrong texture.
I used max9 ,but I try it in max 2016 the problem also exist.
So I think, if have some method to save the currect texture.
here is my code
		fn func_renderTex obj i_size outputFile=
		bitm = bitmap i_size i_size
		bakeMap = diffusemap()
		bakeMap.outputSzX = i_size
		bakeMap.outputSzY = i_size
		bakeMap.fileType = ".tif"
		bakeMap.filterOn = true
		bakeMap.shadowsOn =off
		bakeMap.lightingon = off
		bakeMap.targetMapSlotName = "Diffuse"
		bakeMap.enabled = true
		obj.INodeBakeProperties.addBakeElement bakeMap
		obj.INodeBakeProperties.bakeEnabled = on
		obj.INodeBakeProperties.flags = 1
		obj.INodeBakeProperties.bakeChannel = 1
		obj.INodeBakeProperties.nDilations = 100
		render rendertype:#bakeSelected vfb:off progressBar:true outputFile:( outputFile + ".tif") outputSize:[i_size,i_size] to:bitm
		obj.iNodeBakeProperties.removeAllBakeElements()
Swordslayer
You are saving the image in the vfb - you should instead specify the filepath inside the fileType parameter of the map you are adding. Yeah, it's counterintuitive and fileType is a confusing name when it should more fittingly be named filePath... So delete the outputFile: parameter of the render command, switch the .tif in bakeMap.fileType = ".tif" for the complete path and you're good to go.
thank you Swordslayer ,
I just solved this, just saved diffusemap().bipmap its ok
maybe the rendered buffer in diffusemap() is currect
		bakeMap.fileType = ".dds"
		obj.INodeBakeProperties.nDilations = 500
		render rendertype:#bakeSelected vfb:off progressBar:true outputSize:[i_size,i_size ]
		b_temp = bakeMap.bitmap
		b_temp.filename = ( outputFile + ".dds")
		save b_temp
