QApplication.instance() returns QCoreApplication instance
Message 1 of 8
Hello!
In python, I am trying to get the active QApplication object for Max in order to access top-level information such as the active QScreen, screen geometry, etc.
When I run the tollowing code, I get a QCoreApplication instead of the expected QGuiApplication or QApplication:
QtGui.QGuiApplication.instance()
Is there another method for getting the QApplication?
Replies (7)
Message 2 of 8
drew_avis
Hi, this is a known limitation, and we will document how to work around it.  One solution is to use shiboken2 (included with PySide2) to cast the QCoreApplication to a QApplication, like this:
>>> from PySide2 import QtWidgets
>>> import shiboken2
>>> app2 = shiboken2.wrapInstance(shiboken2.getCppPointer(QtWidgets.QApplication.instance())[0], QtWidgets.QApplication)
>>> app2
<PySide2.QtWidgets.QApplication object at 0x0000020A13D67F08>
Hope that helps,
Drew
Drew Avis
Content Experience Designer
Message 3 of 8
I will try this out ASAP, I spent a long time searching for exactly this workaround.  Thanks!!
Message 4 of 8
Thank you for this, it's very helpful.
I'm curious though. Why does this problem not happen with Autodesk Maya 2018 ? Why does the instance() method return the correct PySide2 type in that application ?
Message 5 of 8
colbey82
I'm running Max 2020, but I can't import shiboken2, if I run your code I get the following error:
Traceback (most recent call last):
ImportError: No module named shiboken2
Any thoughts on what's causing this?
Message 6 of 8
drew_avis
Shiboken2 is part of the PySide2 module in 3ds Max 2020.  Can you try this?
from PySide2 import shiboken2
Hope that helps,
Drew
Drew Avis
Message 7 of 8
bradley_henke
I'm running into this problem on Maya 2020 as well. I've tried using your work around and it seems to work the first time the function is called; however, it seems to stomp on the qApp variable so that any subsequent calls to
PySide2.QtWidgets.QApplication.instance()
return None.
Do you have any other recommendations? Any chance this can patched on Autodesk's end in the same manner as SideFx? (https://www.sidefx.com/changelog/?journal=&categories=&body=&version=18.0&build_0=366&build_1=366&sh...)
Message 8 of 8
jlmunozYTUDK
Community Visitor
Community Visitor
Thanks.
