@pycharm : "3dsmaxpy.exe >> Not a valid home for Python SDK"
Starting working with 3dsmax 2017 and new python script integration.
I use to work with Maya, then pycharm to write scripts.
Usually the ".../Maya2016/bin/mayapy.exe" file works fine with pycharm.
But the ".../3ds Max 2017/3dsmaxpy.exe" file provided leads to an error with pycharm (see attached screen).
Any idea how to correctly setup a pycharm project for 3dsmax python use?
Thanks by advance! ^_-
PS : this is PyCharm software : https://www.jetbrains.com/pycharm/
Replies (7)
Actually even with the python27.dll from the install root folder, it doesn't work 😞 ....
(see attached picture)
I emailed with Kevin Vandecar (Media & Entertainment Manager @ Autodesk) and he responded with:
Hi Martin, Very sorry, but we were not able to get it working with 3ds Max 2017. Product team decided to make a custom version of python, complete with renaming the executable. This causes PyCharm to apparently be confused. I also tried renaming the executable, but then it is not run properly by 3ds Max, as it seems to be hardcoded into exe. We have reported it to engineering. So far, I have had only a couple complaints about it, but I suspect it is just starting to become bigger issue. I also saw recently another complaint here: https://forums.autodesk.com/t5/3ds-max-programming/pycharm-quot-3dsmaxpy-exe-gt-gt-not-a-valid-home-... I will check with engineering to see if they have any news. Sory for the trouble. Kevin
So hopefully support will come in the future.
If you want to run code from PyCharm you could use MaxConnect as in this example: https://github.com/ADN-DevTech/3dsMax-Explode-Geometry/tree/master/Python but debugging doesn't work unfortunately
That's sound a bumch of fun..... 😄
I'll have a try on Monday, thanks!
Do you know if there's a timeframe for this?
Duplicate 3dsmaxpy.exe as python.exe in the main directory.
Pycharm will allow it then.
However, I found that the script fails in Pycharm when you run it but… it works using debug.
The error is
  File "_ctypes/callbacks.c", line 314, in 'calling callback function'
  File "C:\Dev\bin\YCDIVFX_MaxPlus-master\packages\maxconnect\tomax.py", line 197, in _getWindows
    attachThreads(gMainWindow)
  File "C:\Dev\bin\YCDIVFX_MaxPlus-master\packages\maxconnect\tomax.py", line 176, in attachThreads
    thread = GetWindowThreadProcessId(hwnd, 0) #max thread
WindowsError: exception: access violation writing 0x00007FFF00000000
Could not find MAXScript Macro Recorder
Perhaps someone could shed some light on that?
George
I traced the issue and added a couple of line to packages\maxconnect\tomax.py to correct the ropey execution:
See https://github.com/ycdivfx/YCDIVFX_MaxPlus/issues/3 for details
I hope this helps someone.
George
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
