Problem with decimal symbol
kotorotomoto
Message 1 of 29
kotorotomoto
Problem with decimal symbol, maxscript crashes if a comma is set as a decimal symbol in the Windows settings, because it cannot recognize a decimal number, for example, instead of 0.3 it sees 0,3 and understands it as a sequence of numbers. The problem is not new, there is probably a simple solution without changing the regional settings of Windows
The problem looks old, but I haven't found a solution
Replies (28)
Message 2 of 29
istan
I always change the windows regional settings.
There were even certain max versions, which destroyed already stored node/scene props from dot to comma in the scene accidentially.
Therefore I always take care on the proper windows settings, before I open a scene - just to be on the safe side.
To be honest, a dot was and is always the standard floating point separator and not a comma - for a technician at least 😉
Message 3 of 29
denisT.MaxDoctor
 Just want to confirm what is said above... To avoid problems, match the Windows regional settings with the MAX localization version.
Message 4 of 29
denisT.MaxDoctor
commas are for lyrics 😊
Message 5 of 29
istan
Message 6 of 29
kotorotomoto
I completely agree with you, since childhood I have also a dot in decimal symbols set in the settings,
but for many this is not the case and explaining to someone that the script will stop crashing
if you go into the Windows settings is a bad decision )
I found something like
setLocaleInfo 0 #LC_NUMERIC "."
but I didn’t understand how it works and whether it works at all in maxscript
Message 7 of 29
denisT.MaxDoctor
is it your script that is crashing?
are you setting/getting any custom settings from the INI file?
Message 8 of 29
denisT.MaxDoctor
@kotorotomoto wrote:
Problem with decimal symbol, maxscript crashes if a comma is set as a decimal symbol in the Windows settings...
how does a comma appear in a script? MAXScript does not expect a comma in decimal numbers, no matter what localization is used.
Message 9 of 29
kotorotomoto
But sometimes MAXScript gets it regardless of the location settings.
Try it (Vray 5)
Message 10 of 29
kotorotomoto
Message 11 of 29
denisT.MaxDoctor
Try it (Vray 5)
who adds this user property?
where and how do you get this value?
Message 12 of 29
kotorotomoto
I didn’t understand the question, but this is the Vray property of the object, the color of the shadow, any value other than black [0,0,0]
Message 13 of 29
denisT.MaxDoctor
Does it mean that VRay adds these user properties automatically? Or do your users add the props manually?
Do you read these VRay user props in your scripts (tools) or do third-party tools do it?
Message 14 of 29
kotorotomoto
In this particular case with color I get this shadow color in my script and change it to another one using color picker
If I have decimal symbol set to "." everything works without problems if decimal symbol set to "," there are no script errors, but the color doesn't change
Message 15 of 29
denisT.MaxDoctor
You're not answering my question!
Try again...
Does VRay add these custom properties automatically? Or do your users add the props manually?
If VRay does it, you can control only reading the props, if users add the properties, you can give them a tool to do it properly. Capeesh?
Message 16 of 29
kotorotomoto
I don't answer the question because I can't understand its essence, probably lost in translation
There is a task - to get the shadow color in the script's color picker and change it to another.
I get a color this way:   getUserProp obj "VRay_Matte_ShadowColor"
and I change it to another: setUserProp obj "VRay_Matte_ShadowColor" newshadowcolor
color can be different each time. Maybe there is another way, but I didn't find it
If I have decimal symbol set to "." everything works without problems if decimal symbol set to "," there are no script errors, but the color doesn't change. Forcing the user to change the regional settings of windows may cause bewilderment )
That's all
Message 17 of 29
denisT.MaxDoctor
Well...
It makes no difference to the setUserProp function what locale Windows uses.
It always sets a string value with a decimal separator ".".
So my question again:
How did you get "[0,129412,0,0862745,0,0470588]" in the User Defined Props?
Message 18 of 29
denisT.MaxDoctor
you can try to change the Windows locale and set user props in the MAX:
setuserprop $ "VALUE" [pi, e]
setuserprop $ "COLOR" (orange as point4)
with any locale the result has to be the same:
Message 19 of 29
kotorotomoto
Message 20 of 29
denisT.MaxDoctor
If the user props have something like "[0, 129412, 0, 0862745, 0, 0470588]" as a string value, there is no clear and explicit way to decode this into a valid Point3.
So you're left with only the option to prevent such data from getting into the buffer, and no way to read it properly.
