Announcements
Minimum Width in CreateDialog?
alexandre_bisewski
alexandre_bisewski
Hi guys.I am creating a dialog from a rollout using this line:
createDialog _main 800 850  style:#(#style_titlebar, #style_border, #style_sysmenu, #style_minimizebox, #style_maximizebox, #style_resizing)
What is cool is that I can resize my script.
But I need a minimum width and I dont know how do it.
For example: If I change the width to 450 no problens...But when I move to 200 I want to stop here. This is the minimum value. I only can increase this value to turn the script more wider...
I had try to listener the width like if _main.width < 200 do (_main.width = 200) but not worked because the script start to fliker
Thank you
Swordslayer
There's nothing wrong with that approach (ie limiting the size in the resize handler), I do the same see for example Color Mixer, the Qt one. Why not full Qt and instead just one Qt widget in native mxs dialog? Because sometimes you want native controls for their niceties - spinners with keyable controllers or like here the colorpickers to copy-paste to material editor.
denisT.MaxDoctor
@Swordslayer wrote:
There's nothing wrong with that approach (ie limiting the size in the resize handler)...
The problem is the flickering... Depending on your monitor and graphics settings, it can range from just bad to very bad.
denisT.MaxDoctor
try (rol.win.close()) catch()
rollout rol "RO:6D9E22C8" width:400
	local win
	button bt_0 "d" width:(rol.width/6 - 6) align:#center across:6
	button bt_1 "e" width:(rol.width/6 - 6) align:#center
	button bt_2 "n" width:(rol.width/6 - 6) align:#center
	button bt_3 "i" width:(rol.width/6 - 6) align:#center
	button bt_4 "s" width:(rol.width/6 - 6) align:#center
	button bt_5 "T" width:(rol.width/6 - 6) align:#center
	fn create_qt =
		cui.RegisterDialogBar rol
		host_hwnd = UIAccessor.GetParentWindow rol.hwnd
		dbar_hwnd = UIAccessor.GetParentWindow host_hwnd
		sc = GetUIScaleFactor()
		core = python.import "PySide2.QtCore"
		wdts = python.import "PySide2.QtWidgets"
		qwdt = wdts.QWidget
		maxd = qwdt.find (windows.getMAXHWND())
		host = qwdt.find host_hwnd
		root = qwdt.find dbar_hwnd
		root.setAttribute core.Qt.WA_DeleteOnClose
		win = wdts.QDialog maxd
		win.setWindowTitle rol.title
		win.setAttribute core.Qt.WA_DeleteOnClose
		win.setWindowFlags core.Qt.Window
		lt = wdts.QHBoxLayout()
		lt.setContentsMargins 0 0 0 0
		win.setLayout lt
		lt.addWidget host
		win.setMinimumHeight (30 * sc)
		win.setMaximumHeight (30 * sc)
		win.setMinimumWidth (300 * sc)
		win.setMaximumWidth (1000 * sc)
		root.close()
		win
	on rol resized size do
		updateRolloutLayout rol forceUpdate:on
	on rol open do
		win = create_qt()
		win.show()
createdialog rol style:#(#style_resizing) height:-1
... at least it flickers less 😜
