Maxscript Rename textures/materials to filename, change file image extension
system-core
system-core
I have scenes I need a single script to do the following
Change Texture name to filename on disk example: ClutterGenSmallA_d.dds
Change Material name to Texture file name
Change Image extension from .dds to .tga
I already found a script which changes the material to texture name, I cant seem to find a script which changes texture name to one on disk. If I can remove the path from the texture name
from: textures\SetDressing\ClutterGeneric\ClutterGenSmallA_d.dds
to: ClutterGenSmallA_d.dds
select $*
fn renameMats objs = if objs.count != 0 do
	local matClasses = #(Arch___Design__mi, Standard)
	local selMats = #()
	for c in matClasses do
		for o in objs where o.mat != null do (join selMats (getClassInstances c target:o))
	if selMats.count != 0 do
		for m in selMats do
			case of
				(isProperty m #diff_color_map): if isKindOf (map = getProperty m #diff_color_map) textureMap do m.name = map.name
				(isProperty m #diffuseMap): if isKindOf (map = getProperty m #diffuseMap) textureMap do m.name = map.name
	) ; free selMats
renameMats selection
system-core
I found some code that worked to change the texture map name to the same as the filename.
for b in getClassInstances bitmaptex do try(b.name = getFilenameFile b.filename)catch()
dmitriy.shpilevoy
filenameFromPath @"D:\path\texture.tga"
"texture.tga"
osukas
Im trying to do the same, but instead of a 3dsmax bitmap (bitmaptex) im trying to do it with an "Arnold Image" but i cant find the <MaxClass>
EDIT: i found it, is ai_image
for img in getClassInstances ai_image do try(img.name = getFilenameFile img.filename)catch()
inquestudios
MartinBeh
Have you considered doing this in the Asset Tracking System?
It has a function to strip the path from asset names...
Martin B   EESignature
→ please 'Like' posts that are helpful; if a post answers your question please click the "Accept Solution" button.
