MaxScript/Python for Detecting Stretched/Distorted UVs in 3ds Max
razan_ns_hussein
Observer Observer
razan_ns_hussein
Observer
Observer
Hi 3ds Max Scripting Community,
I need a MaxScript/Python solution to identify objects with UV distortion in 3ds Max, similar to the blue and red colors shown in the UV Editor during area distortion visualization.
Details:
  • 3ds Max Version: 2021
Objective: Detect and print the names of objects with UV distortion indicated by blue and red colors in the UV Editor.
Your help is greatly appreciated! If you have a script or tips how to write one, please share.image.png
Thank you!
RGhost77
Hello @razan_ns_hussein !
Do you find any solution?
Royal Ghost | veda3d.com
denisT.MaxDoctor
This is not a complicated thing. What is distortion? Two possible criteria come to mind:
1. The ratio of map face and geo face areas is different than average.
2. The ratio of perimeter (sum of face edge lengths) of map and geo faces is different.
In both cases, we need to calculate the ratio for all faces, find the average, and find the maximum distance from the average. All faces can then be arranged by their ratio distance from the average.
If the ratio is the same as the average, then there is no distortion, it is represented as 0. If the ratio difference equals the maximum, it is represented as 1.
RGhost77
Good point.
But interesting, is the way to access to color map of Area Distortion mode somehow?
It's look like vertex color map but with no access.
denisT.MaxDoctor
I don't think it's easily accessible from any of the channels. The data is stored in the internal buffer and rendered on-the-fly, I suppose.
