Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
I'm trying to access the world position coordinates of the control vertices in a NURBSCVSurface sub object.
The position is always returned as a value relative to the centre of the sub object rather than relative to the world coordinates.
I don't know how to access the pivot point coordinates of the NURBSCVSurface sub object.
If I did, I would just add these to the relative coordinates to get my answer.
I've included a v. simple script below to see what I mean.
To test it, create a simple CV Surf (Create-->Geometry-->NURBS Surfaces-->CV Surf) that isn't centered around the origin (I couldn't attach files for some reason).
objNode = $Surface001 objNode.pos classof(objNode) getset = getNURBSSet objNode #relational -- Get the first NURBSCVSurface sub-object: obj = getObject getset 1 -- Output name of the sub object to listener: obj.name -- Output position of the first control vertex to listener position = (in coordsys local getCV getSet[1] 1 1).pos -- Apply transform to convert to world coordinates (doesn't work): trnsform = obj.transform worldPosition = (position*trnsform)
Solved by Swordslayer. Go to Solution.
Well, I didn't actually open the file and only guess, but what about
getPointPos objNode 1
