3ds Max Programming
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max SDK, Maxscript and Python topics.
Max Scripting
2 REPLIES 2
606 Views, 2 Replies
Max Scripting
How  do i batch process a scene containing 1000 of objects. each object to merge vertices. doing it manually is a tedious work!! Is there any script available any suggestions greatly appreciated!!
2 REPLIES 2
blakestone
The below script will add the "Vertex Weld" modifier to every geometry object in your scene with the threshold setting of "0.1" - change this value as needed.
Delete the commented line if you don't want it to collapse the stack.
    for i in geometry do (
        addModifier i (vertex_weld())
        i.modifiers[#vertex_weld].threshold = 0.1
        collapseStack i -- delete this line if you don't want to collapse the stack
Technical 3D Graphic Artist
Autodesk 3dsMax 2015 - Service Pack 4
in reply to: blakestone
Just what i needed TYSM Smiley Happy
