3ds Max Programming
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max SDK, Maxscript and Python topics.
Max Script programming
4 REPLIES 4
1023 Views, 4 Replies
what is the command flag for random selection in max script??
4 REPLIES 4
Swordslayer
in reply to: Swordslayer
Thank you for the reply i tried it
the function that you create required a selection so i did a
select $*
select (for obj in selection where random 0 1 > 0 collect obj)
it worked but i have to copy the last line command several times to end up with a single selection in the scene as the scene is highly populated with 1000 of objects, is there any simple format of code?
Swordslayer
thanks!!
