Max Script easy position problem
Hey,
I'm new to writing scripts in 3DS Max.
My problem is that when I use the move function the object doesn't move with the value I typed in.
I'll attach a picture where you can see that I want to move the object for 10 units
but the new position is 25,4cm.
Am I doing something wrong or can someone explain this to me?
Is it because the Script language always uses Inch as Unit?
1 Inch = 2,54 cm
Steve_Curley
Customise > Units Setup. You have fallen into the same trap as many other people in thinking that changing the display units is sufficient - it isn't.
Click the big System Units button and change the value in there to cm (1 unit = 1cm) - the default is Inches which is why you're seeing a difference when using Move.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
Thanks a lot
