instancereplace
instancereplace
akaijin
instancereplace
akaijin
I'm pretty newbie about maxscript.
In maxscript ,there is instancereplace method.
So,I want to change to make rollout button and select objects by pushing the bottun.
I tried ,but don't work well.
rollout MYTool01 "instancereplace"
button selectObj_btn  "selectObj" pos:[8,5] width:60
button replaceObj_btn "replaceoObj" pos:[8,30] width:60
button replace_btn "execute" pos:[8,50] width:60
local obj=#()
 on selectObj_btn pressed do
  srcobj= $selection as array
 on  replaceObj_btn pressed do
  dstObj = $selection as array
 on replace_btn pressed do
  instancereplace srcobj dstObj
createDialog  MYTool01 width:600
Is there a way to find a good code,please?
Sorry about my poor English.
miauuuu
	global rol_MYTool01
	try(destroyDialog rol_MYTool01)catch()
	rollout rol_MYTool01 "instancereplace"
		local selObj = undefined
		local objsToReplaceArr = #()
		button selectObj_btn  "Select source object" width:140
		button replaceObj_btn "Select objects to replace"  width:140
		button replace_btn "EXECUTE"  width:140
			selObj = selection[1]
			objsToReplaceArr = selection as array
			if selObj != undefined and objsToReplaceArr.count != 0 do
				instanceReplace objsToReplaceArr selObj
	createDialog  rol_MYTool01
Select only one Source object and press the [Select source object] button.
Then select the objects that you want to be replaced and press the [Select objects to replace] button.
Then press the [EXECUTE] button.
https://miauu-maxscript.com/
denisT.MaxDoctor
here is my version:
pick a "target" object as an object for replace with
select source nodes and apply "Instance Replace"
try(destroydialog instancereplaceDialog) catch()
rollout instancereplaceDialog "Instance Replace" width:210
	group "Target:"
		pickbutton target_bt "Pick Target" width:192 autoDisplay:on align:#right offset:[4,0]
	group "Tools:"
		button replace_bt "Instance Replace" width:192 align:#right offset:[4,0]
	on replace_bt pressed do undo "Replace" on
		if isvalidobj target_bt.object and selection.count > 0 do
			instancereplace selection target_bt.object
createdialog instancereplaceDialog
akaijin
Hi,miauuuu and denisT
Thank you so much!
I can stop worrying about that now.
These scripts works well for group objects !
I'll keep on trying, thanks.
