How to properly stop script execution
maxyweb
Message 1 of 10
maxyweb
Hi everyone!
How to properly stop script execution and unload dll from memory.
Something like
if killer == true then
      exit from script
dll - WPF interface
Replies (9)
Message 2 of 10
denisT.MaxDoctor
Firstly, how was the DLL loaded? ... not every DLL can be unloaded just like that.
Secondly, what is this DLL that needs to be unloaded?
Message 3 of 10
maxyweb
@denisT.MaxDoctor  написал (-а):
dotNet.loadAssembly interface.dll
WPF interface (Several windows and several functions)
The script can be run many times during a session
and it feels like it runs slower each time, eventually crashing
Message 4 of 10
denisT.MaxDoctor
instead of loading assembly by path use
Assembly.Load(File.ReadAllBytes(filePath));
then .NET should take care of the garbage collection itself
I'm pretty sure it's not the loaded UI that you need to care about, but some of the data and resources that were loaded with the tool.
Message 5 of 10
Ken_GordonQRB22
Not working
Unknown property: "load" in undefined
filePath - tried several different path 😕
Message 6 of 10
denisT.MaxDoctor
Not working
Are you familiar with .NET and C#?
Message 7 of 10
Ken_GordonQRB22
At a very low level. I'm starting to try
Message 8 of 10
denisT.MaxDoctor
Where did you get the DLL you are using? I figured you wrote it.
Message 9 of 10
Ken_GordonQRB22
I wrote it
Message 10 of 10
denisT.MaxDoctor
how did you write the dll if you don't know c# and .NET?
Well... if you want, you can post the DLL code. I'll take a look and maybe find memory leak problems and recommend ways to fix them.
