How to get this type of window to select folder
Message 1 of 8
you can get a window to select folder location via getSavePath
but I want to know how can we get the window which looks similar to what is in the screenshot?
Regards
Replies (7)
Message 3 of 8
miauuuu
	local openFileRoll = dotNetObject "System.Windows.Forms.OpenFileDialog"
	openFileRoll.title = "Select Files"
	openFileRoll.Multiselect = true
	openFileRoll.Filter = "MAX (*.max)|*.max"
	openFileRoll.FilterIndex = 1
	openFileRoll.RestoreDirectory = true
	result = openFileRoll.showDialog()
	result.ToString()
	if (result.Equals result.OK) do
		print openFileRoll.fileNames
https://miauu-maxscript.com/
Message 4 of 8
Thank you guys for the prompt response. Really appreciate it! 🙂
Message 5 of 8
Siger_
I think your image show FolderBrowserDialog 🙂
The method of use is very similar to that described above. Only will return the result not filenames, but the path to the directory.
Message 6 of 8
You're right. I did try FolderBrowserDialog but it displayed folder selection in tree view 😕
Message 7 of 8
Siger_
Yes, it is default limitations. Alternatively, you can write your own (not very complicated).
Some other options:
Use Microsoft.Office.Core.FileDialog //Inconvenient way
Use SaveFileDialog with some trick. C# example:
// Prepare a dummy string
string zeroFileName = "Here";
var sfd = new SaveFileDialog();
sfd.FileName = zeroFileName;
if(sfd.ShowDialog() == DialogResult.OK)
    // Here's your save directory
    string savePath = Path.GetDirectoryName(sfd.FileName);
    // Do whatever
 Use WindowsAPICodePack. C# example:
var dlg = new Microsoft.WindowsAPICodePack.Dialogs.CommonOpenFileDialog();
dlg.IsFolderPicker = true;
Another example: https://www.medo64.com/2011/12/openfolderdialog/
Also example: https://www.codeproject.com/Articles/15059/C-File-Browser
etc, etc, etc...
Message 8 of 8
thank you!!! 🙂
