How to get cureent view port camera position and projection matrices?
Hello, How to get current view port camera position and projection? How to capture event, when view port camera is changed? For example user use command zoom or move and camera parameters is changed. How to get this event?  Thank you in advance.
denisT.MaxDoctor
#1 the current(active) view transform is getviewtm() or viewport.gettm()
#2 general callbacks - #viewportchanged
Thank you, it helps me
I use following algorithm to get current view camera.
	//get current view port
        ViewExp *viewPort = &GetCOREInterface()->GetActiveViewExp();
	GraphicsWindow *gw = viewPort->getGW();
        //register redraw call
	GetCOREInterface()->RegisterRedrawViewsCallback(&pccb);
	float mat[4][4];//The transformation matrix times the projection matrix.
	Matrix3 invTM;//This is the inverse of the affine part of the camera transformation matrix
	int persp;//Nonzero indicates this is a perspective view; 0 is orthogonal.
	float hither;//Near clip value.
	float yon;//Far clip value.
	gw->getCameraMatrix(mat, &invTM, &persp, &hither, &yon);
I try render scene with camera projection matrix ("mat"), but Y and Z coordinates are reversedt. what might be happened:Image 2.jpg
If I use cm->SetCoordSystem(IGameConversionManager::IGAME_MAX); all is ok
omidt_gh
How possibly that's going to help, what you asked and write is in C++ SDK and the answer you accept is written in MaxScript !!!! ????
omidt_gh
This is the correct answer in C++ SDK
First, you need to get the view and camera view from it and then use the data you need to.
float FOV = 0;
float focaldistance = 0;
Interval ivalid = FOREVER;
Matrix3 aTM, coordSysTM; // affine and invert affine
Matrix3 invTM; //This is the inverse of the affine part of the camera transformation matrix
Point3 viewDir;
float mat[4][4]; //The transformation matrix times the projection matrix.
int persp; //Nonzero indicates this is a perspective view; 0 is orthogonal.
float hither; //Near clip value.
float yon; //Far clip value.
//get current viewport
FOV = viewPort->GetFOV() * 180 / PI;
focaldistance = viewPort->GetFocalDist();
// The affine TM transforms from world coords to view coords
// so we need the inverse of this matrix
viewPort->GetAffineTM(aTM);
coordSysTM = Inverse(aTM); // if you need the parameters to be inverted
// The Z axis of this matrix is the view direction.
viewDir = coordSysTM.GetRow(2);
