how to develop a standalone software using 3ds max SDK (or C#) to control running 3ds max projects remotely? (Solution uses OLE Automation with C# and maxscript)
FelixP5NJM
Message 1 of 22
FelixP5NJM
If there is another way? Or Is it impossible with normal approaches?
Replies (21)
Message 2 of 22
denisT.MaxDoctor
It's possible, but 3DS MAX must be installed anyway to get not only libs but also some used dlls. So there is no a big difference to make a standalone app or a plugin for 3DS MAX. Where the second is much easier.
Message 3 of 22
denisT.MaxDoctor
Another way is to work with "exported" data from 3DS MAX (OBJ, FBX, etc.) using a related SDK.
Message 4 of 22
FelixP5NJM
Is there an official tutorial about making a standalone app using 3ds max SDK?
Message 5 of 22
denisT.MaxDoctor
I don't think there is anything official from Autodesk about this for 3DS MAX. Unlike Maya, where some time ago such a development was offered and welcomed by Autodesk.
Message 6 of 22
klvnk
what does "to control 3ds max projects?" even mean ? control max ? open max files ?
Message 7 of 22
Swordslayer
Message 8 of 22
FelixP5NJM
such as importing models, creating objects and adding animations. Other things can be done with plug-ins, but I need to make them a standalone application.
Message 9 of 22
klvnk
just use OLE automation then, you can make max dance to the tune of python, C/C++ etc to your hearts content.
this is a console app (written in c++)  using OLE to run the script sent to it (in this case from sublime text editor)
Message 10 of 22
FelixP5NJM
Thank you. But does it need libraries provided by AutoDesk to make it work, or do you just write code from scratch?
Message 11 of 22
klvnk
the console app is written from just windows libraries.... it needs Max to be OLE enabled and provide the server side functions (which is documented in MXS help). Exposing a run script function is useful as it minimizes the server side work required even if it's not the most efficient.
Message 12 of 22
FelixP5NJM
I followed the instructions in the doc.
After I wrote a "runScript" function and exposed it. How can I connect my program (for example, in C++) to a 3ds max instance and invoke the "runScript" function with the parameter (script file name)?
Message 13 of 22
klvnk
Message 14 of 22
trykle
I think you still need to install the whole 3dsmax and run it, then you can use cmd to pass parameters, there is a 3dsmaxbatch.exe in the 2018 version, it may be more convenient.
Message 15 of 22
FelixP5NJM
Thank everyone's help. I finally find an easy solution using C# on GitHub. Here is the link.
This was all I need after registering 3ds Max and exposing the Maxscript function "filein".
using Westwind.Utilities;
string prog_id = "Max.Application";
Type com_type = Type.GetTypeFromProgID(prog_id);
object com_obj = Activator.CreateInstance(com_type);
com_obj.GetType().InvokeMember("filein",																 ReflectionUtils.MemberAccess | BindingFlags.InvokeMethod,																  null, com_obj, new object[] {filepath});
With this, I can control 3ds Max to run any Maxscript files.
Message 16 of 22
denisT.MaxDoctor
Hmm.. I remember you were talking about "standalone" .. no longer?
Message 17 of 22
denisT.MaxDoctor
As far as I understand, if MAX runs, then talking about "standalone" does not make sense.
Message 18 of 22
klvnk
"remote" maybe a better description
Message 19 of 22
FelixP5NJM
Sorry about that, I don't understand the definition very well. I am developing a "standalone" app and "control 3ds max" is just one of the functionalities.
Message 20 of 22
FelixP5NJM
Thank you, I will update the question.
