how to delete selected layers
manue154
Message 1 of 13
manue154
There is an easy way to delete all selected layers and all inside, (like their nested nodes, objs, nested layers...)?
by advance, thanks
Replies (12)
Message 2 of 13
Swordslayer
layerExplorer = SceneExplorerManager.GetActiveExplorer()
if layerExplorer != undefined do
	local objs = #(), layers = #()
	mapped fn collectObjs item =
		if isKindOf item Base_Layer then
			append layers item
			join objs (refs.dependentNodes item)
			items = (for c = 1 to item.getNumChildren() collect (item.getChild c).layerAsRefTarg)
			collectObjs items
		else append objs item
	collectObjs (layerExplorer.SelectedItems())
	delete objs
	for layer in layers where layer.canDelete() do LayerManager.deleteLayerByName layer.name
Message 3 of 13
manue154
Thank you again, it's magic!!! you know all about maxscript! thank you for your generosity 🙂
Message 4 of 13
denisT.MaxDoctor
this line can be a source of mistake. a dependency can be out of hierarchy
Message 5 of 13
manue154
arf.... do you know what can i put instead?
Message 6 of 13
Swordslayer
I'd be curious to see an example for this case.
Message 7 of 13
manue154
anyway, i'll test it at work 🙂
Message 8 of 13
denisT.MaxDoctor
ca = attributes ca
	parameters params
		_layer type:#maxobject
delete objects
sp = sphere()
a = LayerManager.newLayer()
custattributes.add sp ca baseobject:off
sp.ca._layer = a.layerAsRefTarg
format ">> % == %\n" (refs.dependentnodes a.layerAsRefTarg) (a.getNumNodes())
Message 9 of 13
Swordslayer
@Anonymous wrote:
ca = attributes ca
	parameters params
delete objects
sp = sphere()
Hey, that's cheating Smiley Very Happy Yeah in this case getting the nodes with the usual method would of course be better 🙂
And because I always liked your challenges and tricks, do you have any snippet in mind where saving a layer this way could be useful (more than this 'just because I can' example)?
Message 10 of 13
denisT.MaxDoctor
i had a scripted manipulator object that showed nodes in different layers using different specified by user LOOK (color, shape, i don't remember what else) ...
that manipulator had to have the same dependency issue
as you understand the storing layers names couldn't work well because of renaming case and no 'layer reference change' message
same dependency issue we will have with plugins, modifiers, controllers, etc
Message 11 of 13
manue154
heu...i'm not understand anything....
but do you know why if i apply this perfect code to delete a list in an array (and to found inside a specific layer)
i've got this answer in the listener:
-- Error occurred in anonymous codeblock; filename: ; position: 878; line: 31
-- Compile error: No outer local variable references permitted here:  Layers
--  In line:                             append layers i
LayerToFoundArr = #("Asset1", "Asset2", "Asset3")
	mainLayerName = "LayerName"
	mainLayer = LayerManager.getLayerFromName mainLayerName
	function GetObjectsInLayer layer: =
		local objsArr
		layer.nodes &objsArr
		objsArr
	numChildLayers = mainLayer.getNumChildren()
	if numChildLayers != 0 then
		for i = 1 to numChildLayers do
			ChildLayersTmp = mainLayer.getChild i
			ChildLayersName = ChildLayersTmp.name
			for o = 1 to LayerToFoundArr.count do
				selLayersArr = for o in ChildLayersName where (matchpattern o.name pattern:("*" + LayerToFoundArr + "*")) collect o
				if selLayersArr.count != 0 do
							append layers item
							collectObjs items
						delete objs
Message 12 of 13
Swordslayer
Duly noted, might come in handy some time. Wonder what would happen if the layer was saved in a RefTargContainer instead and opened in a different scene. Not at max, but guess it should still work, properties should be retrievable etc. and maybe it could be even switched with an existing scene layer using replaceReference. Gee, I'd have so many questions...
Btw. check your private messages.
Message 13 of 13
denisT.MaxDoctor
it was something changed in the layers system since nested layers were added (2016+). i'm not sure now how it works. but by theory it has to be the same ReferenceTarget as was saved and be loaded with scene
as i said... sometimes there is no practical use of storing a layer in paramblock but it can be a solution to receive reference change messages. I've used it many times
