Announcements
Generate a bitmap texture from script
I am writing a Python script that, among other things, generates bitmaps derived from some data. It then sets them as distribution maps on ForestPack. See the example code below.
The bitmap is successfully created and Display()ed properly (See attachment Bitmap_Display.png)
However, when I create a BitmapTex and use SetBitmap to set the previously created bitmap, the texture appears blank (black), both in the material editor and when applying it (as a distribution map for ForestPack), see attachment BitmapTex_Material_Library.png.
Any clues? The only remotely related post I found was this one, and it says that SetBitmap is "no use".
The only relevant documentation example just creates a bitmap, but it does nothing with BitmapTex. However, ForestPack expects a Texmap or subclass as input for its density map.
Edit: is it at all expected that setting a bitmap from memory works? Is it required to reside in a file? It is not an absolute requirement for me to use a bitmap in memory, but it is preferable.
BMM_GRAY_8 = 3 # 8-bit grayscale bitmap.
BMM_FLOAT_GRAY_32 = 18 # 32-bit floating-point (non-compressed), monochrome/grayscale
BMM_OPEN_W = 2
width = 256
height = 256
data = [[random.random() for i in range(width)] for j in range(height)]
bm_name = "python_noise"
storage = MaxPlus.Factory.CreateStorage(BMM_GRAY_8)
info = storage.GetBitmapInfo()
info.SetWidth(width)
info.SetHeight(height)
info.SetName(bm_name)
info.SetGamma(2.2)
info.SetBitmapType(BMM_GRAY_8)
storage.Allocate(info, BMM_OPEN_W)
# now set the data on the bitmap storage
for x in range(width):
	for y in range(height):
		storage.Put16GrayFloat(x, y, data[x][y])
bm = MaxPlus.Factory.CreateBitmap(info)
bm.SetStorage(storage)
bm.Display(bm_name) # this works
bt = MaxPlus.Factory.CreateDefaultBitmapTex()
bt.SetMapName(bm_name, True) # wtf, isUIAction has to be true for Display to work...
bt.SetBitmap(bm)
# add it to material library
MaxPlus.MaterialLibrary.GetCurrentLibrary().Add(bt)
# now the bitmap texture is blank
drew_avis
Hi there, when I tried this in MAXScript, I notice that you get an error when trying to create a BitmapTexture based on an in-memory bitmap (to the effect that the bitmap needs to be saved first).  So I tried updating your script based on this idea, and it works for me.  Here's the updated script with the changed/added lines highlighted:
import random
BMM_OPEN_W = 2
width = 256
height = 256
# bm_name = "python_noise"
bm_name = MaxPlus.PathManager.GetImageDir() + r'\python_noise.bmp' # must give the full path
# set name w/ path
info.SetGamma(2.2)
info.SetCustomFlag(0)
# save as a file <- this is new
bm.OpenOutput(info)
bm.Write(info)
bm.Close(info)
bt.SetBitmap(bm)
bt.ReloadBitmapAndUpdate() # <- I also needed this to update the BitmapInfo w/ file information it requires
# should be usable
Drew Avis
Content Experience Designer
