Foliage vertex normals editing in 3ds Max
haoze0221
haoze0221
When I was making trees in 3dsmax, I encountered a problem about vertex normals. In order to get better light and shadow effect, I needed to adjust the vertex normals of leaves. I found some scripts online that can pass vertex normals, most of them are spherical normals:VertexNormal
although some light and shadow problems have been solved. But the final volume is not ideal. I tried to do a script myself, by getting the normal orientation of the face and then do a certain flip, but the effect is very unsatisfactory.
I found in Horizon's documentation that their approach to leaf normals looks like a normal transferred from some wrap shape.
Is there a way to generate such an inclusion model in 3dsmax and pass normal information through it to the original model?
Replies (11)
denisT.MaxDoctor
I have a simple question... How long does it take an artist to make an average foliage geometry, including mapping and material?
haoze0221
Hi Denis, I'm also confused that artists always want to automate repetitive operations that don't take much time to make themselvesi
denisT.MaxDoctor
An artist spends at least an hour creating a tree..... there is nothing wrong with spending another 5 minutes to create a few spheres around the “clouds of foliage”.
So, the topic of “automatic” creation is solved and closed, I guess. Now we can focus on “normal things”.
Now another question: Do we need to modify vertex normals? I expect that you will use a normal map anyway. Wouldn't it be easier to create the right texture?
denisT.MaxDoctor
I did a quick geometry around the leaves. It took about 5 minutes.
After that, all is simple:
src=$leaf2
trg = $normals
rm = RayMeshGridIntersect ()
rm.Initialize 100 --init. the voxel grid size to 100x100x100
rm.addNode trg
rm.buildGrid()
for v=1 to src.numverts collect
	f = rm.ClosestFace (getvert src v)
	n = getfacenormal trg f
	setnormal src v n
update src
need a better approximation? go ahead, make a closer target mesh, and tesselate it enough...
Can the algorithm be improved, and the result as well? Yes, it can... but first, we need to discuss what's wrong with it.
denisT.MaxDoctor
Not bad! 😊
haoze0221
I found a script in blender that came close to the expected result. It used voxels to generate the inclusion model, then passed vertex normals, and got a nice AO, but it didn't quite work as well as the Horizon document. The inclusion completely filled all the leaf clusters, resulting in a lot of vertex normals facing down. The inclusions in Horizon are more like the outer outline based on the overall leaf.
Unfortunately blender is not part of my workflow and I can't find anything like it in 3dsmax.
denisT.MaxDoctor
I don't know. Mine looks good to me.
dmitriy.shpilevoy
Hi, Denis. Script executes without errors, but gives strange results.
Am I using it wrong?
Lowest max I can save to is 2021 so sending FBX instead.
denisT.MaxDoctor
It was my mistake. I used the wrong interface and didn't double-check. It should be (MeshProjIntersect)
	mi = MeshProjIntersect()
	mi.SetNode target_node
	mi.Build()
	target_mesh = snapshotasmesh target_node
	cc = for v=1 to source_mesh_node.numverts collect
		pos = getvert source_mesh_node v
		if (mi.ClosestFace pos doubleSided:true) do
            face = mi.GetHitFace()
			norm = getfacenormal target_mesh face
			setnormal source_mesh_node v norm
dmitriy.shpilevoy
Thank you for updated version. "isset" was giving me error
-- Type error: Call needs function or class, got: undefined
Not sure this is the right way, but removing it seems to work. Ended up with:
	source_mesh_node = $leaf2
	target_node = $normals
	mi.Build()
		if (face = mi.GetHitFace()) do
	update source_mesh_node
 This gives expected result with just a couple of artifacts.
denisT.MaxDoctor
isset is my function 😁 It means not 0, not false, not undefined, and if count is defined, it's not zero.
I fixed the code
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
