Announcements
Creating multiple keyframes
leeminardi
Mentor Mentor
leeminardi
I created the following code to calculate the location of the end of a boom from a bus (trolley) to an overhead cable.
-- positions PointCable on line001 a distance LabelControl
-- from PointBus
-- v .01 2/6/2022 L. Minardi
clearlistener()
fn CalculateCablePoint =
select $line001
cable = $
select $PointCable
pCable = $
sM = [0,0,0]
global delta = 0.1
global s = delta
global L= 20.
select $Bus
BusT = $.transform
select $PointBus
pBus = $.position
sA = 0.0  -- % along value for A
sB = delta  -- initial % along guess for B
flag = true
pA = interpCurve3D cable 1 sA  -- point A
pB = interpCurve3D cable 1 sB   -- point B
dA = distance pBus pA
dB = distance pBus pB
-- get to intervale containing solution
for i = 1 to 10 while flag do
(if dB > L then
	pA = pB
    sA = sB
    sB = sB + delta
else
  ( flag = false
-- interval found, now iterate between A and B
flag = true
for i = 1 to 5 while flag do
  sM = (sA + sB)/2.
  pM =  interpCurve3D cable 1 sM
  dM = distance pBus pM
  err = abs(dm - L)
  if (err < (0.01 * L)) then
  (	flag = false
   format ("i = %, error = %   ") i err
if dM < L then
   pB = pM
   sB = sM
else
   pA = pM
   sA = sM
) -- end for
pCable.pos = pM
CalculateCablePoint()
  It works for a single location of the bus.  I am trying to enhance it to generate keyframes as the bus moves.  I have tried adding a For loop for the entire program  and then the following statements to create keyframes at the end of the code. Note, pM is the point location of for the point object PointCable which the boom references with a LookAT constraint.
	select $PointCable
	pCable = $
	slidertime = j
	with animate on
	pCable.pos = pM
 The keyframes are created but they are all the location and do not track along the cable as the bus moves.  Here's the version with the loop.  Any suggestion as to how to get it to generate keyframes for each calculation of pM?
-- from PointBus
-- v .02 2/7/2022 L. Minardi
clearlistener()
clearSelection
--fn cp =
--with animate on
for j = 1 to 15 do
	select $line001
	cable = $
	select $PointCable
	pCable = $
	sM = [0,0,0]
	global delta = 0.1
	global s = delta
	global L= 20.
	select $Bus
	BusT = $.transform
	select $PointBus
	pBus = $.position
	sA = 0.0
	sB = delta
	flag = true
		(if dB > L then
			pA = pB
			sA = sB
			sB = sB + delta
		else
		  ( flag = false
	-- now iterate between A and B
	flag = true
		sM = (sA + sB)/2.
		err = abs(dm - L)
			(	flag = false
		if dM < L then
			pB = pM
			sB = sM
			else
			pA = pM
			sA = sM
	) -- end for
	pCable.pos = pM
	clearselection()
	select $PointCable
	pCable = $
	slidertime = j
	with animate on
	pCable.pos = pM
) -- end for j
lee.minardi
istan
for what reason you
a) always "select" nodes?
b) do "pCable.pos=pM" right before clearselection() ?
Besides, I'd use a different solution by sphere/line intersection.
leeminardi
@istan wrote:
for what reason you
@istan thank you for your comments.   My post was to help me in solving a bigger problem that is better described in this thread. With help from @denisT.MaxDoctor the need for generating keyframes has been eliminated.
As for using a "sphere/line intersection" approach the task is more complex if by "line" you meant straight line.. The path is a spline and there may be multiple solutions or none at all. I think a numerical solution works best in such a situation.
lee.minardi
