CreateDialog and then execute a function or press button?
dg3duy
dg3duy
Is it possible to start a function after using Create Dialog?
Another possibility that can help me is that after Create Dialog a button is automatically pressed. Thank you
miauuuu
As Swordslayer told you:
	global rol_test
	try(destroyDialog rol_test)catch()
	rollout rol_test "Test"
		button btn_pressMe "Press Me"
		function ShowTheTime =
			startTime = getLocalTime()
			format "Time is % \n" (startTime[5] as string + ":" + startTime[6] as string + ":" +startTime[7] as string )
		on btn_pressMe pressed do
			print "Button pressed"
		on rol_test open do
			ShowTheTime()
			btn_pressMe.pressed()
	createdialog rol_test
https://miauu-maxscript.com/
dg3duy
both Swordslayer and miauuuu hit the target, solve the obstacle!
thank you very much to both
