convert boolean true or false into float in a float script controller?
Hello friends, here I am with noob questions again.
My need is simple: I want to switch controllers in a list on or off using a custom attribute with a boolean checkbox.
If I debug the float script, i can see that switch (my variable) evaluates to true or false.
So what I'm trying is:
if switch = true
then 1.0
else if switch = false
then 0.0
else switch
The script evaluates to 0.0 no matter what the switch is set to.
Why doesn't this work? Thanks in advance for your time.
Steve_Curley
= is for assignment, == is for tests. You need to use == in your example.
Also, you don't need to test for equality - "if switch then" is equivalent to "if switch == true then".
Your code, assuming you're using the Checked property, makes no sense as "switch" can only ever be true or false - you only need one test, but you're catering for 3 conditions (which would only be correct if you used Tristate instead of Checked, but then the tests would be incorrect as Tristate is an integer, not a boolean).
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
Thanks very much, Steve. I tried this:
if switch == false
then 0
else if switch == true
then 1
And  it's evaluating 0 or 1. I think the info about == being for tests made the difference.
Great forum. Thanks again!
Steve_Curley
You still only need one test:-
if switch then 1 else 0
-- or
if (switch == True) then 1 else 0
Or
if (not switch) then 0 else 1
-- or
if (switch == False) then 0 else 1
You don't need to test both conditions because failing one condition means the variable is, by definition, the other condition - booleans can only have 2 states.
Max 2016 (SP1/EXT1)
Ah!
Ok thanks, Steve, putting that in the memory banks now. Much appreciated.
