Collapse Animation using Max script?
niels2HFLZ
Message 1 of 13
niels2HFLZ
Heya!
For my project I need to manually bake all objects that have constraints and controllers!
The Conversion Tools layout under Motion > Motion paths is very usefull for this:
But it's very bothersome to navigate..
Everytime you click on the Motion Paths tab it wants to create the all of the visual lines in the vieport.. and with a lot of objects moving around in a big file just hangs for 5 minutes straight.
Also having to manually type in the range is also not ideal.
I was just wondering, if at all, it was possible to acces these functions via script!
So I can for example just make a BAKE button on a toolbar that collapses the pos, rot and scale of the selected objects and automatically sets the sample range to the current active time time range.
Thanks for your time!
Replies (12)
Message 2 of 13
istan
Since all controllers, their calculations and the time/animation-control is scriptable - yes, this is possible. Btw, also possible from C++.
Message 3 of 13
chengshunvfx
Ran into this problem as well.
Is there a solution for this in Maxscript or Python?
I used a script to record the transforms of bones and set them back as controllers frame by frame. But it is much slower than the built-in Collapse Transform function when the number of bones is about 500 and the timeline is 100 frames.
Are there any docs on Maxscript or SDK for Collapse Transform?
Message 4 of 13
MartinBeh
Maybe this is useful?
https://scripts.breidt.net/#mbCollapse
Martin B   EESignature
→ please 'Like' posts that are helpful; if a post answers your question please click the "Accept Solution" button.
Message 5 of 13
denisT.MaxDoctor
How slow is your script? Please provide numbers for 500 baked bones at a 0-100 interval.
Message 6 of 13
denisT.MaxDoctor
delete objects
pp = for k=1 to 500 collect (point())
with animate on at time 100 (move pp [100,0,0]; rotate pp (angleaxis 45 z_axis))
	disablerefmsgs()
	animate on, redraw off
		for p in pp do
			tms = for t = animationrange.start to animationrange.end collect (at time t p.transform)
			k = 0
			for t = animationrange.start to animationrange.end collect (at time t p.transform = tms[k += 1])
	enablerefmsgs()
	for p in pp do notifydependents p
This snippet demonstrates that straightforward MXS "key baking" takes about a sec for 500 nodes on the 0-100 interval.
To do everything correctly you also must sort nodes by hierarchy before the baking.
If you need to do it even faster, you can perform all read and write transforms in one pass of the animation range time loop. This will speed things up considerably.
Message 7 of 13
chengshunvfx
The script I used is very similar to the one you mentioned.
It works correctly, but too slow.
Message 8 of 13
chengshunvfx
About 10-15 minutes in total.
The scene is a complex rig. Skinning bones are constrained by Biped bones.
I want to bake the animation frames of the skinning bones and export them to Maya
Message 9 of 13
denisT.MaxDoctor
the MCR script doesn't do the job correctly.
Message 10 of 13
denisT.MaxDoctor
built-in Collapse Transform doesn't collapse Biped bones!
Message 11 of 13
denisT.MaxDoctor
To export animation to Maya you need only FBX import/export with baking animation key-per-frame
Message 12 of 13
chengshunvfx
It works.
Thanks Denis
Message 13 of 13
in_human
macroScript AnimBake category:"IN_tools"
global bakeobjArr, baketransArr, bakenameArr, opaArr, fnumArr
rollout storeAnim "Bake Animation v1.33 JSON edition"
  group "Time"
    spinner startT "Start: " range:[-9999999,9999999,animationRange.start] type:#integer fieldWidth:45 align:#center across:2
	spinner endT " End: " range:[-9999999,9999999,animationRange.end] type:#integer fieldWidth:45 align:#center
  checkbox controlCheck "assign controllers" align:#center
  button store "Store" width:100
  button restore "Restore" width:100 enabled:false
  label nodeFind "Find node by:"
  checkButton handleButton "Handle" across:2 align:#center width:90 checked:true
  checkButton nameButton "Name"  width:90
  label stateString "ready"
  on handleButton changed state do
    nameButton.state = not state
  on nameButton changed state do
    handleButton.state = not state
  on store pressed do
    bakeobjArr = #()
	bakenameArr = #()
	baketransArr = #()
	opaArr = #()
	fnumArr = #()
	--max time start
	--max time forward
	--max time back
	if $!=undefined do
      for i in selection do
 	    append bakeobjArr i.handle
	    append bakenameArr i.name
	    append baketransArr #()
		append opaArr #()
		append fnumArr #()
      for j=startT.value to endT.value do
        --max time forward
		for i=1 to selection.count do
		  --slidertime = j
		  at time (j as time) append baketransArr[i] selection[i].transform
		  --at time (j as time) append opaArr[i] selection[i].visibility.controller.value
		  --if (custattributes.count selection[i])==1 do at time (j as time) append fnumArr[i] selection[i].fnum
		  stateString.text = j as string
	  stateString.text = "stored"
	  restore.enabled = true
  on restore pressed do undo "Bake animation" on
	for i=1 to bakeobjArr.count do
	  if handleButton.state then curObj = maxOps.getNodeByHandle bakeobjArr[i]
	                        else curObj = getNodeByName bakenameArr[i]
	  if (curObj != undefined) and controlCheck.state do
	    curObj.controller = transform_script()
		curObj.controller = prs()
	    curObj.position.controller = linear_position()
	    curObj.rotation.controller = tcb_rotation()
	    curObj.scale.controller = linear_scale()
    --slidertime = startT.value
	for j=startT.value to (baketransArr[1].count + startT.value - 1) do
	  with animate on
		if curObj != undefined do
				at time j curObj.transform = baketransArr[i][j + 1 - startT.value]
				--animate on curObj.visibility.controller.value = opaArr[i][j]
				--if ((custAttributes.count curobj)==1) do animate on curObj.fnum = fnumArr[i][j]
		--format "%\n" ((startT.value+j-1) as time)
	  --slidertime += 1
createDialog storeAnim width:280
