Cloned material callback
elpie89
elpie89
Hello I have a custom MaxMAterial and I need to execute some code when the material is cloned
I saw there is a method `on clone orig do`  but I want to retrieve the target and call a C# function on it
Right now I'm registering to a #mtlRefAdded callback but this is called even when the file is opened
Do you have any idea on how to do it?
denisT.MaxDoctor
you should use "on clone" anyway. This event handler gives you the original plugin instance and your current one (which receives the event) is the target. You have access to both the source and the target and you can get all the parameters and states of both.
elpie89
Thanks, I didn't figure out this
I was debugging printing "this.name" and the result was always the original name
Only printing an actual parameter I realized that "this" is the new cloned material
Another question how do we pass material between maxscript and C# ?
I need to call a c# method in maxscript loading a dll
that is the easy part
ones I called the method I cannot figure out how to actually pass the material as an object to the C# method
Assembly = dotNetClass "System.Reflection.Assembly"
dllPath = symbolicPaths.getPathValue(1) + "\mydll.dll"
Assembly.loadfrom dllPath
maxScriptManager = dotNetObject "MyNamespace.MaxScriptManager"
maxScriptManager.myMethod(this)
so now how should I retrieve "this" that in my case is a material in the C# side?
Thanks for your help
Serejah
Get the handle from 'this' and pass it to the other side
anim_handle = getHandleByAnim this
On c# side you can have it back using this:
GlobalInterface.Instance.Animatable.GetAnimByHandle( (UIntPtr)anim_handle );
