Check out my new application, Ultimate Max Plus.
Search on YouTube for 'Ultimate Max Plus' or click the link Ultimate Max Plus Link .
"Check out my new application, Ultimate Max Plus. I developed and designed this application to solve the most common problems facing 3ds Max users: arranging blocks and models in folders. Many of us have downloaded extensive block libraries, but we don't have the time to organize or rename the files. In the end, we get confused and don't know which file to use.
Ultimate Max Plus helps you organize 3ds Max block models and obtain preview images for them if found, allowing you to choose the best ones. It arranges all files and folders for use in 3ds Max. You can use the output files either by merging them or using 3ds Max Project Manager or Connecter. With this powerful application, you can save both time and money. It is compatible with all versions of 3ds Max files, both older and newer.
Benefits:
Time and Money Savings: Ultimate Max Plus efficiently organizes and manages 3ds Max block models, resulting in time and cost savings.
Scalability: It can handle any number of folders and files.
Efficiency: The application is designed to be fast and lightweight on your PC, ensuring smooth performance.
Modern User Interface: The application features a modern user interface that enhances the user experience. It also includes custom themes, allowing you to personalize the appearance according to your preferences.
Wide Range of Supported Formats:
Supported 3ds Max Files: Old and new versions of 3ds Max.
Supported Archive Formats: Rar, Zip, 7z, tar, gz, bz2.
Supported Preview Image Formats: JPEG, JPG, PNG, BMP, GIF.
Supported Renders Formats: V-Ray, Corona, NVIDIA, Fstorm, Maxwell, Octane, Redshift, ART, Arnold, Scanline, VUE, QuickSilver.
System Usage:
RAM: 28 MB
Disk Space: 36 MB
System Requirements:
Windows 10 or higher with Dot NET 4.8.1
Minimum RAM: 8 GB or higher
Minimum hard drive: 500 GB or higher
GPU: 4 GB or higher
CPU: Intel Core i3 or higher"
