Can I change command panel buttons? like delete some, add some?
Is there a way to rearrange the command panel buttons of a specific modifier so that I can delete some and leave only the ones I need to work with?
Using 3ds max For Architectural purposes could let you use not more than 10% from edit poly buttons, same thing for edit spline and others, I'm trying to find a way to make the user interface easier and adjustable, which I believe will increase the speed of work.
