Batch maxscript to read .csv files run a script and save .max files
system-core
Message 1 of 16
system-core
create sphere from names in text file with this format
PlayerHouse_Shower01001|10|0|0|0|12
clearlistener()
adata = (dotnetClass "System.IO.File").ReadAllLines @"C:\test.txt"
for i = 1 to adata.count do
pInfo = (filterString adata[i] "|")
print pInfo
s = sphere segments:(pInfo[6] as integer)
s.radius = pInfo[2] as integer
s.pos = [pInfo[3] as integer,pInfo[4] as integer, pInfo[5] as integer]
s.name = pInfo[1]
move/rotate/scale objects from csv with this format
Name        Position                                   Rotation                    Scale
PlayerHouse_Shower01001,-80331.0938,90976.4297,7857.2979,0.0000,-0.0000,230.8562,1.0000
TreeMaplePreWar01Gr001,-99744.5547,77048.9453,10398.3457,0.6550,-0.6280,269.8729,0.9100
    file = memStreamMgr.openFile @"C:\test.csv"
    while NOT file.eos() do
        local line = filterString (file.readLine()) ","
        if line.count == 8 AND isValidNode (local obj = getNodeByName line[1]) do
            obj.pos = [line[2] as float, line[3] as float, line[4] as float]
			obj.rotation = eulerAngles (line[5] as float) (line[6] as float) (line[7] as float)
            obj.scale = [line[8] as float, line[8] as float, line[8] as float]
    memStreamMgr.close file
I wanted to modify the scripts above to save a max file, based on a csv file name that the script reads.
I've got hundreds of files with different names test.csv for example. the code should do the following
read file test.csv
create one object per name from the csv file, PlayerHouse_Shower01001 TreeMaplePreWar01Gr001...etc (can be a sphere/dummy/box)
run the script code position/rotation/scale
save test.max (Based on read csv filename)
reset
read next csv file
repeat until end of files
If anybody can help give me some examples or help me figure out how to do this I would appreciate it. Thankyou
Replies (15)
Message 2 of 16
denisT.MaxDoctor
lt is true that you always have a pair of .txt and .csv files with the same name in the same directory, and you need to create a max file with the same name in the same directory as the original pair?
Message 3 of 16
system-core
Yes same name same folder, the max file can be saved in the same folder or the 3dsmax/scenes is okay. Ideally I just want to process the csv data which also has the names to create objects. I created the csv.txt with names only in the first script to  generate spheres. I had to use notepad++ to manually add |10|0|0|0|12 it's tedious
Message 4 of 16
denisT.MaxDoctor
It sounds like you don't need TXT file at all. The CSV already tells you the name of object and its matrix3.
The type of the object could be any (dummy for example) with predefined size.
Message 5 of 16
system-core
Yes thats right, I have searched all over the internet for some code I could use, I don't have much knowledge to write code.
Message 6 of 16
denisT.MaxDoctor
struct TheCSVBatchStruct
private
	caption = "Choose a Folder for CSV Batch...",
	read_all_lines = (dotnetClass "System.IO.File").ReadAllLines,
public
	dummy_size = 100,
	last_dir,
	fn make_matrix data =
		if data.count == 8 then
			pos = [execute data[2], execute data[3], execute data[4]]
			rot = (eulerangles (execute data[5]) (execute data[6]) (execute data[7])) as quat
			scl = execute data[8] * [1,1,1]
			translate (rotate (scalematrix scl) (inverse rot)) pos
		else (matrix3 1)
	fn process dir: saveCheck:on =
		if not saveCheck or checkforsave() do
			if dir == unsupplied do dir = getSavePath caption:caption
			if iskindof dir String and doesfileexist dir do
				pattern = pathConfig.appendPath dir @"*.csv"
				csvs = getfiles pattern
				format "directory: %\n" dir
				format "\tprocess CSV files:\n"
				for c in csvs do
					resetmaxfile #noPrompt
					setSaveRequired off
					format "\t\tCSV: %\n" (filenamefrompath c)
					format "\t\t\tnodes:\n"
					ss = read_all_lines c
					for s in ss do
						data = filterstring s ",;"
						if data.count == 8 do
							name = data[1]
							tm = make_matrix data
							node = dummy name:name boxsize:(dummy_size * [1,1,1]) transform:tm
							if isvalidnode node do
								setSaveRequired on
								format "\t\t\t\t%\n" name
					if getSaveRequired() do
						m = replace c (c.count-2) 3 "max"
						format "\t\t\tMAX: %\n" (filenamefrompath m)
						res = savemaxfile m clearNeedSaveFlag:true useNewFile:false quiet:true
						format "\t\t\t\t%\n" ((if res then "SUCCEEDED" else "FAILED")	)
	on create do
csv_batch = TheCSVBatchStruct()
-- default run:
csv_batch.process()
-- expert run if you exactly know what to do:
csv_batch.process savecheck:off dir:@"C:\temp\Tests"
buy me a beer if it works  😉
PS. some bug was fixed
Message 7 of 16
denisT.MaxDoctor
@system-core wrote:
... I have searched all over the internet for some code I could use, I don't have much knowledge to write code.
It's very hard to find something that works for a specific task... ChatGPT is not yet developed enough in this area to be trusted... so for now all that's left is to learn how to code on your own.
And yes... You could also ask someone who knows how to do it. 😎
Message 8 of 16
denisT.MaxDoctor
In reality, of course, batch tools are much more complex if you want to do it right. The main challenge is to make the batch robust and stable enough to complete the job, and informative enough to tell you about the process (track progress and statistics, log warnings and errors, etc.).
Message 9 of 16
system-core
I've tried the script and got the following in the listener
#Struct:TheCSVBatchStruct(
  last_dir:<data>; Public,
  make_matrix:<fn>; Public,
  read_all_lines:<data>; Private,
  dummy_size:<data>; Public,
  caption:<data>; Private,
  process:<fn>; Public)
(TheCSVBatchStruct dummy_size:100 last_dir:undefined)
OK
Am I supposed to add a folder path to "Choose a Folder for CSV Batch..." I did and I get the same text as above in the listener. I don't see anything happening and no files are created? Thanks for helping me
Message 10 of 16
denisT.MaxDoctor
do you run:
csv_batch.process()
Message 11 of 16
denisT.MaxDoctor
do you run:
csv_batch.process()
Message 12 of 16
system-core
No I just ran 3dsmaxbatch.exe C:\script.ms with cmd prompt. I'm a bit confused how to run it; and if I need to add a directory or does it let me select one What is the csv_batch.process() how would I run that. Thanks
csv_batch.process()
Message 13 of 16
denisT.MaxDoctor
1. open max
2. run the code I sent
3. run :
csv_batch.process()
Message 14 of 16
system-core
I'm not sure what you mean here is a picture of what I have, I ran EvaluateAllimage.jpg
Message 15 of 16
denisT.MaxDoctor
Un-comment bottom of the script. And evaluate all again
Message 16 of 16
system-core
Yes it works, Thanks for that how could I donate some money for that beer
