Assign random vertex color per element
Message 1 of 13
Hi, im using substance painter a lot and i have to assign to my objects random vertex colors to each element to make selections. Is there any script to do this automatically? ty
ps. if there is someone using substance too and knows other way of passing selections into substance im all ears 🙂
Replies (12)
Message 2 of 13
Swordslayer
If random vertex color per element is enough (which may or may not result in duplicates, changing seed might help sometimes), you can use dataChannel modifier for that:
Message 3 of 13
Swordslayer
And as a script that ensures unique colors:
fn shuffle arr =
    for counter = arr.count to 1 by -1 collect
        local swapIndex = random 1 counter
        swap arr[random 1 counter] arr[counter]
fn incrementCounters &r &g &b step =
    if (b += step) > 256 do
        b = 1
        if (g += step) > 256 do
            g = 1
            if (r += step) > 256 do r = 1
fn getElements mesh =
    local vertCount = mesh.numVerts
    local faces = mesh.faces as bitArray
    local facesByVert = for v = 1 to vertCount collect #()
    for face in faces do
        local faceVerts = getFace mesh face
        append facesByVert[faceVerts[1]] face
        append facesByVert[faceVerts[2]] face
        append facesByVert[faceVerts[3]] face
    for face in faces collect
        local i = 0, element = #(face), elementVerts = #()
        while (local f = element[i += 1]) != undefined do if faces[f] do
            faces[f] = false
            for v = 1 to 3 do facesByVert[faceVerts[v]] =
                for vertFace in facesByVert[faceVerts[v]] where faces[vertFace] collect
                    append element vertFace
                    append elementVerts (int faceVerts[v])
                    dontCollect
        elementVerts as bitarray
fn assignUniqueElementColor obj op shuffleElements:off =
    local elements = getElements (snapshotAsMesh obj)
    local stepCount = elements.count^(double 1/3) + 1
    local step = 255./stepCount
    local redArr = shuffle (#(0) + #{1..255})
    local greenArr = shuffle (#(0) + #{1..255})
    local blueArr = shuffle (#(0) + #{1..255})
    local r = 1, g = 1, b = 1
    if shuffleElements do
      elements = shuffle elements
    for element in elements do
        op.setVertColor obj 0 element [redArr[int r], greenArr[int g], blueArr[int b]]
if isKindOf $ Editable_Mesh then assignUniqueElementColor $ meshop shuffleElements:on
else if isKindOf $ Editable_Poly do assignUniqueElementColor $ polyop shuffleElements:on
If you instead want to bind it to a shortcut, you can save it as a .ms file and use the macroscript creator to make a macro for it.
Message 4 of 13
Thanks again, exactly what i needed 🙂
Message 5 of 13
One more q: this script is independent to data channel modifier and cant be used in previous max versions? thanks again
Message 6 of 13
Swordslayer
Yes, it works with any editable mesh / editable poly that's currently selected and should work across most of the old max version, more than a decade back at the very least.
Message 7 of 13
Jixal
Hey, this is super cool.
Is it possible to do the same but apply to all objects instead of just elements?
For example, I have 9 objects that will be textured in Substance Painter and I want a random vertex color for each object (to use as an ID mask).
Message 8 of 13
Swordslayer
Something like
fn smootherStep x =
    x * x * x * (x * (x * 6 - 15) + 10)
fn shuffle arr =
fn assignUniqueVertexColor objs shuffleItems:off seed:0 =
    local maxVal = 256^3 - 1d0
    local maxCount = objs.count
    local counter = 0d0
    if shuffleItems and ::seed seed == OK do
        objs = shuffle objs
    for obj in objs do
        local clr = smootherStep (counter / maxCount) * maxVal
        if isKindOf obj Editable_Poly do polyOp.setVertColor obj 0 #all [bit.shift (bit.and clr 0xff0000) -16, bit.shift (bit.and clr 0x00ff00) -8, bit.and clr 0x0000ff]
        counter += 1
assignUniqueVertexColor (getCurrentSelection())
Message 9 of 13
denisT.MaxDoctor
 ::seed seed
I like it 🙂
Message 10 of 13
Jixal
Thanks 😃
Message 11 of 13
I tried to use data channel for vertex color element, but it seems that it kills uv map channel...
Your script run fine. Thanks
Message 12 of 13
Jixal
Hi all,
Joker Martini just released a really nice script that does everything that we want for vertex colouring objects and elements- https://jokermartini.com/product/vertex-color-editor/
Lightweight, simple and slick. Love it.
Message 13 of 13
alnoman.7cgi
Observer
Observer
This is very useful. thanks for the effort!
could it be easy to convert wirecolor to vertex color for all objects or selected objects?
Thanks.
