A way to control Render Map Dialog with MAXScript
Hi.
I am not a programmer. I might use the wrong terminology here but I will try to do my best 😊
We are looking for a way to use the MAX Render Map Dialog to render complex map setups into a single map.
This is an example of a material
And this is the MAX description for it: Render Map Dialog
Is there a way to run this dialog with MAXScript? We want to render maps like color correction or composite with the Render Map Dialog into a bitmap and reconnect those exported maps to the material slots because the complex material setups cannot be exported to other software. We have many materials where this is needed and therefore looking for a way of automatization.
I would be very grateful for your help or ideas.
Thank you! We will test it.
Topspap.1994
Hi
Did You find a solution using a script ? if yes Could you share the script ?
Thank you
