A question about MAXScript
panghsheng
Message 1 of 10
panghsheng
I want to implement a functionality where, in the currently active SME view, I search for all VRayMtl nodes. If found, I check if the node connected to the diffuseMap port is a VRayBitmap. If it is, I modify coords.blur to 0.01. If not, I traverse all output ports of the material until I find a VRayBitmap and set its coords.blur to 0.1. Below is my code, but I don't know why it's throwing errors.
function setVRayBitmap m =
    diffuseMap = m.diffuseMap
    if isKindOf diffuseMap VRayBitmap do
        diffuseMap.coords.blur = 0.01
    if not isKindOf diffuseMap VRayBitmap do
        for i = 1 to m.numOutputs() do
            outputMap = m.getOutputMap i
            if isKindOf outputMap VRayBitmap do
                outputMap.coords.blur = 0.01
               return
function SMEGetMatsInView =
    viewNode = sme.GetView (sme.activeView)
    for n = 1 to trackViewNodes[#sme][(sme.activeView)].numSubs do
        m = trackViewNodes[#sme][(sme.activeView)][n].reference
        if classOf m == VRayMtl do
            setVRayBitmap m
SMEGetMatsInView()
Replies (9)
Message 2 of 10
denisT.MaxDoctor
What is this, a game? Do we have to guess the errors first and then tell you how to fix them?
Message 3 of 10
panghsheng
Thank you for your reply.
Message 4 of 10
panghsheng
Thank you for your reply. This is not a game. I want to batch change the parameters of VRayBitmap, as shown in the figure below. In the currently active view window of SME, I want to batch change the value of coords.blur of VRayBitmap. However, the value depends on which port it is in VrayMtl. If it is under diffuseMap, the value of coords.blur of VRayBitmap is 0.1. If it is under reflectionMap, the value of coords.blur of VRayBitmap is 0.01. Or if it is under BumpMap, the value is 0.03.dd3cda8b4e0e1267369de7d39a0f1fe.png
Message 5 of 10
denisT.MaxDoctor
post the error messages you get... screenshots of the message box and the log from the listener
Message 6 of 10
panghsheng
Okay, thanks again for your response。:)692681fabefaf57f379ef8615b83911.png
Message 7 of 10
denisT.MaxDoctor
at line 16 of your code should be
return ()
this is why you should post "errors"...
Message 8 of 10
panghsheng
This is the result after adding parentheses. I suspect there might be an issue with the logic of the entire code.cfd6aa3bc564dbcda31b469fd38b547.png
Message 9 of 10
denisT.MaxDoctor
the error log tells you everything... "in line 10 the material doesn't have a method or property #numOutputs"
so see the documentation on how to get the correct number of VRay material outputs
Message 10 of 10
denisT.MaxDoctor
Step by step, we'll first correct all the syntax errors, then move on to the logical ones... and then, possibly, to the stylistic ones.
