A map that takes mapping from other object.
Piotr-Glabski
Piotr-Glabski
I'm  new to programming, but I wonder if it would be even possible to make a script to have a map (like a bitmap map) that contains pickup button and takes mapping from selected object without having UVW Map modifier placed?
That would mean that moving the object would keep the mapping from static object not from the mapping on the object (like it is now with UVM Map and inherit absoulte mapping).
So when the INSTANCED object is moved the mapping (for example plannar) is still taken from the reference object, not from UVW Map...
Or maybe there is an other solution?
I don't know if it is a proper forum, I wish to know if it is possible before I'll start to try to write a script...
Replies (0)
