Zeroing one component of a quaternion
I need to rotate an object by the difference of two quaternions, but I need to consider only the y and z components of this difference. How can I zero only the X component?
use slerp to interpolate between quats, then do a conversion to eulers, zero x then convert back to quats
You should read the mxs docs section on rotations. It may be confusing at first, but keep at it...it will sink in.
Why the interpolation?
sorry...you're right slerp isn't needed...coffee hasn't worked for me lately
(this assumes you have three point helpers named point01 - point03)
foo = ($point01.rotation - $point02.rotation)
foo_euler = foo as eulerangles
foo_euler_zero = (eulerAngles 0.0 foo_euler.y foo_euler.z)
rotate $point03 foo_euler_zero
