WM_INITDIALOG in ParamMap2UserDlgProc
What are the rules to disable ParamBlk2 items on a panel?
I did an EnableWindow() in WM_INITDIALOG but all ParamBlk2 controls are still active - in contrast all standard windows controls behave correct. Even when I can disable these controls later, every "repaint" of the dialog panel puts them to enable again?
class cPanel2DlgProc : public ParamMap2UserDlgProc
public:
HWND hWin;
cPanel2DlgProc() {}
INT_PTR DlgProc(TimeValue t, IParamMap2 *map, HWND hWnd, UINT msg, WPARAM wParam, LPARAM lParam) {
switch (msg)
case WM_INITDIALOG:
HWND h = GetDlgItem( hWnd, IDC_PBLK2ITEM );
if (h)
EnableWindow( h, false ); // <<< this one fails..
break;
void DeleteThis() { }
I've put similar code to NotifyRefChanged() func. In my case, I have material type and some ui should be disabled for some types. So, when material type is changed ui can be disabled.
You can do same thing in CreateParamDlg()
IParamMap2* pMap = PBlock->GetMap( YOUR_ROLLOUT );
if( pMap ){
HWND hWnd = pMap->GetHWnd();
EnableWindow(GetDlgItem( hWnd, YOUR_CONTROL ), false);
Hi Michael,
to be honest, I do not see any difference. The HWND is exactly the same.
The question is where all I have to add this code, as every refresh of the UI enables the dlg controls again.
Istan
That's strange, it shouldn't be enabled just be refreshing. May be you are doing something wrong in other place?
What kind of plug-in you making? Is it object? Material? Modifier?.. Do you use P_MULTIMAP for ParamBlock? What type of control you trying to disable?
For example, to disable 3dsmax custom control (such as buttons, spinners etc) you should take ICustom<Type>* and call Disable():
ICustButton* pICustBtn = GetICustButton(GetDlgItem(hWnd,IDC_CUSTOMBUTTON));
pICustBtn->Disable();
ReleaseICustButton( pICustBtn );
Solved!!! My general "Enable" function failed in getting the Cust control pointer properly.
Thanks!
You are welcome 🙂
