Wiring OSL output nodes
andres.hernandezB63FL
Hi everyone!
I'm very much stuck with this one so I was wondering if someone could give me a hand.
I have created two OSL nodes:
idOSL.OSLpath = (getdir #maxroot) + "/OSL/" + "GetMtlID.osl"
mapOSL.OSLpath = (getdir #maxroot) + "/OSL/" + "Float1ofN.osl"
I need to connect to the mapOSL(Float1ofN) index input, the index output of the idOSL(GetMtlID), but I can't find a way to access to the specific out since the GetMtlID has 2 outputs (color and index)
I really appreciate any help.
Thanks a lot
I found the solution. If anyone is stuck with the same, you need to use the texture map "MultiOutputChannelTexmapToTexmap ".
So in my case it would be something like this:
outMap = MultiOutputChannelTexmapToTexmap sourceMap:idOSL outputChannelIndex:2
mapOSL.index_map = outMap
campion_kirkham
Observer
Observer
Thank you for sharing your solution!
