Volume Select Gizmo
Volume Select Gizmo
Volume Select Gizmo
Hey...
Im tearing my hair out trying to figure this one out... I'm making a tool for quickly setting up muscles between two points, and the code is this;
macroscript muscleSetup
category:"Toke Scripts"
fn muscleBone type =
p1 = selection
p2 = selection
muscle = BoneSys.createBone p1.pos p2.pos
muscle.boneFreezeLength = off
muscle.boneScaleType = type
muscle.position.controller = Position_Constraint ()
muscle.position.controller.appendTarget p1 100
muscle.rotation.controller = Lookat_Constraint lookat_vector_length:0
muscle.rotation.controller.appendTarget p2 100
muscleNull = BoneSys.createBone
muscleNull.pos = p2.pos
muscleNull.parent = muscle
muscleNull.position.controller = position_constraint ()
muscleNull.position.controller.appendTarget p2 100
fn muscleCylinder type =
p1 = selection
p2 = selection
dist = (distance p1.pos p2.pos)
muscle = cylinder height:dist sides:8 heightsegs:5
muscle.pos = p1.pos
muscle.boneEnable = true
addmodifier muscle (xform())
muscle.modifiers.gizmo.rotation += quat 0 0.707107 0 0.707107
addmodifier muscle (volumeselect level:1 useAffectRegion:true falloff:(dist/2))
muscle.modifiers.gizmo.scale =
muscle.modifiers.gizmo.position =
--searching through scene for other muscles and instances modifier
flexMuscles = for i in geometry where i.boneEnable == true and classof (i.modifiers) == flex collect i
if flexMuscles.count > 0 then
tempMod = flexMuscles.modifiers
addmodifier muscle tempMod
)else
addmodifier muscle (flex flex:0.16 strength:4 sway:15)
rollout rollout_muscleSetup "Muscle Setup"
group "Step 1"
label lb1 "Select two points."
group "Step 2"
label lb2 "Choose type"
radiobuttons muscleType labels:#("scale","squash")
group "Step 3"
label lb3 "Choose muscle"
button cylinderBN "Cylinder w. Flex"
button boneBN "Bone"
on boneBN pressed do
if muscleType.state == 1 then
muscleBone #scale
)else
muscleBone #squash
on cylinderBN pressed do
muscleCylinder #scale
)else
muscleCylinder #squash
createdialog rollout_muscleSetup style:#(#style_titlebar,#Style_toolwindow,#style_sysmenu)
The tool stops when trying to access the vol. select modifiers gizmo, and says "Unknown Property". When I copy the exact same code into the listener and execute it, I get the gizmo scaled down and repositioned as I want it.
Has anybody had similar problems or know of a solution?
completeRedraw() -- seems that volume select gizmo can only be accessed after it has been registered properly in the scene, so force a complete redraw
It's not that elegant, almost feels like a bug, but it works.
-Johan
Perfect! nevermind about the elegance:-) Here is the finished script:
p1 = selection
p2 = selection
p1.name = (uniqueName "MuscleStart_")
p2.name = (uniqueName "MuscleEnd_")
muscle.name = (uniqueName "Muscle_")
p1 = selection
p2 = selection
muscle = cylinder height:1 sides:8 heightsegs:10 name:(uniqueName "Muscle_")
muscle.pos = p1.pos
muscle.modifiers.gizmo.scale +=
addmodifier muscle (ffdBox ())
setDimensions muscle.modifiers
completeRedraw()
muscle.baseobject = flexMuscles.baseobject
)else
addmodifier muscle (flex flex:0.2 strength:4 sway:10)
group "Step 1"
group "Step 2"
group "Step 3"
muscleBone #scale
)else
muscleBone #squash
)else
