Vista / Max9 issue
Vista / Max9 issue
Vista / Max9 issue
I originally posted here area.autodesk.com/forum/Autodesk-3ds-Max/3ds-max-through-2008/vista-andor-64-bit-issues-with-plugins/#9858
But was told maybe this forum might be better. I have an internally developed plugin that works fine on Max 9 / XP32 and Max2K8 / Vista64, but does not work on Max9 / Vista64. There is no obvious problem with the plugin and no error messages, but it sounds like others have run into this issue with other plugins? Anyone know of an obvious problem?
I don't think it has to do with the operating system. I think it depends on whether the
installed Max9 application is 32-bit or 64-bit.
You basically have to compile both 32-bit and 64-bit versions of your plugin.
You can't mix and match them.
