Announcements
UVW mapping modifier edit
This part of the script runs fine. However if there is an object that doesn't have a UVW Mapping modifier on it then the script will barf. What I need is to add a line to check to see if that modifier exists, but not sure of the syntax. Any ideas?
Here's the code snippet
objArray = geometry as array
-- get all geometry objects into array
for i = 1 to objArray.count do
objArray.modifiers.length = 128
objArray.modifiers.width = 128
Cheers
Steve_Curley
If you want just the objects which have a UVW Map modifier:-
objArray = for o in geometry where (o.modifiers != undefined) collect o
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
