Using PySide in 3ds Max 2017 - MaxPlus.GetQMaxWindow issue?
Having a weird issue with MaxPlus, simply getting the main max window.. doesn't seem to be working.
From the docs, this method: QtGui.QWidget(MaxPlus.GetQMaxWindow()) is the way to get the qmainwindow in a qwidget..
the problem is that MaxPlus.GetQMaxWindow() returns nothing, and whenever i put it into a variable, or within a qwidget, or even check if its valid with PySide.shiboken, it always returns no value, not even None.
The error i get when trying to run it within a gui, is Unknown exception thrown executing script and nothing else.
Can anyone shed some light on this?
thanks in advanced.
-Dan
DDelapenaZ28WA
To add to this, what is interesting is that the Personal version of 3ds Max i have at home, i have the above issue.. at work, i do not.
It's important to note, if i run import sys; print sys.argv, it returns [''], which i find very odd. This should return something.
On top of this, when i get random python errors within my tools... the error i get is 'Error occured executing user action' and no other information.. is there a 'show stack trace' check box somewhere?
DDelapenaZ28WA
Just noticed, on a machine that it works on.. i'm on windws 7. On the machine it doesn't work, i'm on windows 10. Perhaps this is the problem?
