unknown property
unknown property
unknown property
HELLO
when 3DMaxs run a screen shown says ( unknown property :
"unmitems" is undefined i try to repair it then i delete it and
return it back but the other screen says ( synnatx error expected name -- in lin ) shown how i can solve this
this issue  make the 3DMax files slower and heaver and i can't continue  my work
? best regrades
NOW whan i try to click cusmized 3d max stop working
denisT.MaxDoctor
MAX says you that you have a bad code running with the system. It tells you the script's filename, line of wrong syntax, and some 'guess' what is wrong.
you only need to fix the code.
or post the code to let other people help you with it
Thank you
i solve the problem by installing another version of 3d max
 i think the problem was with the v-ray
best regards
