Announcements
Track View selected item(focus)
Does anyone know what the correct syntax to get the currently highlighted controller in the track view? (ie box-transform-position-Z position) Thank you
Swordslayer
This will get you the controller:
	local currentTV = trackViews.current
	local selCount = currentTV.numSelTracks()
	for i = 1 to selCount collect currentTV.getSelected i
 You can get its parent by calling
currentTV.getParentOfSelected i
If you only want to get the expression for it, you can also use exprForMAXObject.
Okay, I'm nearly there. I just need to convert the parent type of controller into the form of position/rotation.controller and I'm not sure how to do that
--clear the listener
clearListener()
-- put everything in brackets
	local currentTrackView = trackViews.current
	if (currentTrackView != undefined) then
		local numOfTracks = currentTrackView.numSelTracks()
		for i = 1 to numOfTracks collect
			local theParent = currentTrackView.getParentOfSelected i -- controller
			-- Parental check
			if (theParent != undefined) then
				local theSubnum = currentTrackView.getSelectedSubNum i -- axis number
				local theSubanim = getsubAnim theParent theSubnum -- anim type
				selectKeys $Box01.position.controller[theSubnum].controller -- works
				selectKeys $Box01.theParent[theSubnum].controller -- doens't work!!!!
	else messageBox ("No trackview open, dude")
-- selectKeys $Box01.position.controller[3].controller --Z
Swordslayer
So you are only interested in the position/rotation controllers?
	fn getPosRotController ctrlTrack currentTV posRotController:false =
		while isController ctrlTrack AND NOT posRotController do
			posRotController = isKindOf ctrlTrack RotationController OR isKindOf ctrlTrack PositionController
			if NOT posRotController do ctrlTrack = currentTV.getParent (currentTV.getIndex ctrlTrack)
		if posRotController then ctrlTrack
		local posRotCtrls = for i = 1 to numOfTracks collect
			local posRotCtrl = getPosRotController (currentTrackView.getSelected i) currentTrackView
			if posRotCtrl == undefined then dontCollect else posRotCtrl
		-- if you want to select all the keys belonging to pos/rot controllers, this is enough:
		selectKeys posRotCtrls
		-- if you want to work with the resulting array, just filter out the duplicates:
		makeUniqueArray posRotCtrls
