TEXTPLUS
TEXTPLUS
richardvillagaray
TEXTPLUS
richardvillagaray
I don't know how to program TextPlus to measure the distance between two points. I want to do it with Maxscript because I have to do it several times.
denisT.MaxDoctor
disableRefMsgs()
delete objects
enableRefMsgs()
	global txt = textplus name:#test pos:[0,0,30] dir:-y_axis alignment:0 isselected:on wirecolor:red
	scr = point name:#source pos:[0,0,0] wirecolor:green
	trg = point name:#target pos:[100,0,0] wirecolor:yellow
	title = "Distance(m) : "
	txt.setPlaintextString title
	txt.setvalueastext -1 "Distance" #script #whole 0 0 true
	ss = txt.baseobject[#Distance].controller = float_script()
	ss.addnode "source" scr
	ss.addnode "target" trg
	ss.setexpression "distance source target"
	txt
richardvillagaray
Dear Dennis:
I thank you in advance for your support in resolving this matter. I have 3ds Max 2020, and the code does not run.
Appears the next message.
denisT.MaxDoctor
it needs SP2 for 2020
richardvillagaray
Yes.
It work fine.
A lot of thanks !!
denisT.MaxDoctor
deleted
richardvillagaray
Hi Dennis
I want to put a "FACTOR", TO CHANGE the units of distance (pass meter to ft, or another). Please can you help me ??
I want to "concatenate text" to the value of textplus.
Please, help me.
