Message 1 of 1
System exception
01:32 AM
Whilst coding a maxscript I got a system exception - checking the code I was dividing two numbers (one of which was a zero). I corrected the code but I found that I was unable to hit CTRL + E to evaluate the code. I ended up having to pick another script, run that and then switch back to the original script. Now I've just tried this with a simple script printing 10/0 to get the system exception; however I am able to evaluate the script again as normal. Has anyone else experienced problems when the evaluate all command doesn't appear to do anything? it seems a bit random but apart from the workaround (or a restart of Max) is there anything else I can do?
Keep calm and remain scripting.
Cheers
Cheers
