Sub Object selection count Info in vewport
altup1515
altup1515
Is it possible SubObject selection (vertexes/edges/polygons) count Info/statistics display on the viewport?
  • UI
altup1515
may be it can be on center of screen?
denisT.MaxDoctor
unregisterRedrawViewsCallback GW_displayObjectNames
fn GW_displayObjectNames =
  gw.setTransform (matrix3 1)
  for o in objects where not o.isHiddenInVpt do
    gw.text o.pos (o as string) color:yellow
  gw.enlargeUpdateRect #whole
this is an example from the MXS Help (gw Graphic Window Drawing Methods)
tweak it a little for yourself, and write what you want where you want. 😉
because there is no built-in option to display scene statistics on the screen.
