SoulburnScripts Updated Jan 15th 2008
Message 1 of 1
First off, I've finally tested the scripts in 3dsmax 2008, and everything is working fine. The scripts also work fine in both 32bit and 64bit.
Added 1 new script:
subdivisionAutomator: Quickly assigns a subdiv modifier (meshsmooth or turbosmooth) to all scene or selected objects. This is good if say you want to have all objects in your scene converted into subdivs at rendertime without the need to constantly select objects, find the right modifier, assign the modifier, etc.
Updated 2 scripts:
texmapPreview: Added doublesided material support. Also now the pattern can be applied as a bump or diffuse (default).
objectReplacer: Fixed a bug I introduced last version that stopped the selection set function from working properly.
http://www.neilblevins.com/soulburnscripts/soulburnscripts.htm
Thanks to everyone for your support.
- Neil
Replies (0)
