Slider move
Slider move
Message 1 of 8
Slider move
I have made an array of all position controller keys of
main camera.
Now i try to slider move on each key and copy targetdistace
of main camera to free camera.But cant sucess to move slider.
How can i move slider in forloop on each keys ?
Thanx
Replies (7)
Message 2 of 8
you can either use the global variable sliderTime or currentTime, or simply us a context:
sliderTime=5
with animate on (your code here)
at time 5 do with animate on (your code here)
Message 3 of 8
Thank you its works
I have save all value of Camera002 in myTransform.
Assign this value to free camera which is made by script.
myTransform =$Camera002.Transform
In my script everything works fine.
No error.
When i add this script to (on came picked obj do(...))
Its give me error on line myTransform =$cam.Transform
"MAXScript Rollout Handler Exception: -- Unknown property: "transform" in undefined <<"
Find the script below...
Thanx
rollout pick_box_test "Pick Box Test"
--filter all objects of class Box:
fn box_filt obj = classof obj == Targetcamera
--Pickbutton to select a Box from the scene
pickbutton chooseit "Select Camera" width:140 filter:box_filt
--If the user picked an object, then
on chooseit picked obj do
--see if the user did not cancel the picking...
if obj != undefined do
--if he did not, make the box's wireframe red:
--obj.wirecolor = red
--and display the name of the object on the button:
chooseit.text = obj.name
cam = chooseit.text
print cam
freecam = Freecamera ()---Create free camera
freecam.transform = myTransform --align freecamera to main camera
select freecam
$.Target_Distance = $cam.targetDistance
$.parent =$cam --link free camera to main camera
posKey = $cam.pos.controller.keys --make an array of all keys
print posKey
--$Camera01.pos.controller.keys--returns array of position keys
animate on
for i = 0 to 500 do
select freecam
at time i $.Target_Distance = $cam.targetDistance
--m= posKey
)--end on
)--end rollout
createDialog pick_box_test
Message 4 of 8
$cam refers to an actual object in the scene named "cam".
You need to use the variable obj, which is the node returned by the pickbutton.
Message 5 of 8
Thank you very much
Message 6 of 8
Hi everyOne,
I have made script which copy all target distance of main camera
to free camera.Keys made on every frame.
But i try to make the key only made on main camere's key.
I make an array of all position key of main camera.
But cant success to move slider on that array's value.
animate on
for i = animationRange.start to animationRange.end do
select freeCam
at time i $.Target_Distance = $Camera002.targetDistance
$.fov = $Camera002.fov
How can i move slider at main camera's key and made free camera's key?
Thanx
Message 7 of 8
keys = $Camera002.fov.controller.keys
frames = for k in keys collect k.time
for t in frames do
at time t animate on
Message 8 of 8
Thank you so much
