slice with 1 point vertex
anycganycgJ8A6A
anycganycgJ8A6A
hi  , i need help some from freinds
i use swift loop common
but that is not snap
pls  so i need this code~~~
if i   select  1 vetext ,   and  check   x    or  y  or  z
then     that is slice along  x axis
.... etc
is  1-point- axis- slice  possible ~~
denisT.MaxDoctor
try(destroydialog PolySliceRol) catch()
rollout PolySliceRol "PolySlice by denisT" width:200
	label slice_dir_lb "Direction:" across:2
	radiobuttons slice_dir_rb labels:#("X","Y","Z") columns:3
	button slice_bt "Slice" width:182 align:#right offset:[4,4] tooltip:"Select Any vertex and splice the Poly"
	on slice_bt pressed do undo "Slice" on
		if iskindof (node = selection[1]) Editable_Poly do
			if node.selectedverts.count > 0 do
				p = node.selectedverts[1].pos
				d = case slice_dir_rb.state of
					1: x_axis
					2: y_axis
					3: z_axis
				polyop.slice node #all (ray p d)
				update node
createdialog PolySliceRol
anycganycgJ8A6A
really really thank you , i use code below
but    first object is good work . but other  object is error
pls can you teach ~~
savesnap=snapMode.active
snapMode.active=true
while NOT keyboard.escPressed do
in coordsys local pta = pickpoint snap:#3d
if classOf pta == point3 do
sx = pta[1]
sy = pta[2]
sz = pta[3]
npx = [sx+300,sy,sz]
ptd = ( npx - pta )
nptd = normalize ptd
na = nptd[1]
nb = nptd[2]
nc = nptd[3]
in coordsys local $.EditablePoly.slice [na,nb,nc] pta flaggedFacesOnly:off
snapMode.active=false
macros.run "Selection" "SmartSelect"
