Simplemod - world coordinates
I`m writing a scripted modifier that snaps vertices to a grid position in world space.
The only problem I`m having is finding out the world position of each vertex.
I only need to get this position as I can then alter the local position accordingly.
Does anyone know a way of getting the world position of 'p'?
I`ve included the WIP plug-in below;
plugin simpleMod SnapToGrid
name:"Snap to Grid"
classID:#(0x3891aa38, 0x51b5e565)
version:1
parameters main rollout:params
amount type:#integer ui:amtSpin default:2
rollout params "Snap Parameters"
spinner amtSpin "Grid Val: " type:#integer range:
on map i p do
p.x = P.x-(Mod (p.x+min.x) (amount*39.3701))
p.y = P.y-(Mod (p.y+min.y) (amount*39.3701))
p.z = P.z-(Mod (p.z+min.z) (amount*39.3701))
p
The vertices obviously live in the local coordinate space of the object the mod is applied to, so you'll need to add the local pos to the object pos.
You could store the baseObject in the parameters with a weak reference and access it's position in the map handler to calculate the worldPos.
That's a great idea. I`m not sure you can access the object directly from within the map handler as it's referencing itself causing an infinite loop.
I`m starting to wonder if this is actually possible to do as a simplemod can also be applied as an instanced modifier over multiple objects.
