setMapVert not showing color changes in viewport
tagopinath
tagopinath
Hello Everybody,
3ds Max SDK :
I have a mesh object created using the Mesh class. I am trying to set face colors using setMapVert for the mesh.
I found some code in MaxScript (https://forums.cgsociety.org/t/vertex-color-in-viewport-max-2009/1563863/4), when I tried this without converting into either poly or mesh, then colors changes are not happening. If I convert my mesh into poly or mesh, then, the script is working fine.
I tried to implement this using SDK, but i am getting the same result which i got while running the script (not converting to poly or mesh)
The following codes, added as a script (for testing)
setCVertMode $ on
$.vertexColorType = 5
$.vertexColorMapChannel = 1
meshop.setmapsupport $.mesh 1 on
meshop.applyuvwmap $.mesh #face channel:1
The following, i have added in sdk.
the_mesh.setMapVert(1, the_mesh.faces[fIdx].v[0], clr);
the_mesh.setMapVert(1, the_mesh.faces[fIdx].v[1], clr);
the_mesh.setMapVert(1, the_mesh.faces[fIdx].v[2], clr);
I am updating the mesh and calling redrawviews also.
Is this the method of implementing? What i am doing wrong?
can anyone please suggest me ideas how to implement this logic?
Gopinath.
tagopinath
I was able to solve this. No need for below two lines
and, i need to change the mapping channel (say, some 6 or 7) and for that, i need to set texture vertices and set default color.
the other codes mentioned, works fine.
Thanks again.
Gopi.
