Set Xref Material with script
bertv
bertv
I'm trying to set a Xref Material with Maxscript. But without success so far.
I can create the material, but I'm unable to set the file  name ref for some reason.  The object ref works fine.
local fileName = getOpenFileName
$.material = XRef_Material name:"my_xref_mat" srcFileName:fileName srcItemName:"box"
Any ideas?
10DSpace
@bertv
You forgot the () after
getOpenFileName
try
filename = getOpenFileName()
and the filename should be returned.
bertv
The path reads out correctly now
local fileMerge = getOpenFileName()
$.material = XRef_Material name:"item01" srcFileName:fileMerge srcItemName:"item01"
Problem I can't manage to link the Xref material correctly this is how the shader looks.
It says status: Unresolved Xref, File Not Found
I think it has something to do with Xref objects. But not sure how to set this by script.
Regards
Bert
10DSpace
@bertv
"I think it has something to do with Xref objects. But not sure how to set this by script."
See link below:
https://help.autodesk.com/view/3DSMAX/2016/ENU/?guid=__files_GUID_8B7E81F0_AC81_4518_8D8E_B0C9C67176...
denisT.MaxDoctor
you think it right... you have to do "merging" first. for example to "add new xref object":
xrec = xrefs.addnewxrefobject <xref_file> <object_name> #proxy dupMtlNameAction:#useXRefed
-- xrec is an object if all was merged well
<my_object>.material = xrec.material
-- you can name the material
delete xrec
bertv
Wow,
Thanks for the info.
The Xref materials is working with your code @denisT.MaxDoctor
Regards
Bertv
